Date/Time: Mon, 13 Jan 2025 18:42:49 +0000
trading options with SC/IB
View Count: 1170
[2017-05-05 05:57:38] |
onnb - Posts: 662 |
It is generally possible to trade futures options and equity options with SC using IB?
[2017-05-05 06:04:28] |
Yes.
[2017-05-05 06:10:09] |
onnb - Posts: 662 |
Is there an api to access an options chain for some underlying? I'm aware there is an api to place orders on symbols that are not the current chart and that this api has some limitations regarding order management. So it is generally possible to have a study applied to an ES chart and then place orders on ES options? |
[2017-05-05 06:11:39] |
No API for options chain. So it is generally possible to have a study applied to an ES chart and then place orders on ES options?
Yes.
