Date/Time: Mon, 13 Jan 2025 18:37:31 +0000
Candle pattern alert across chartbooks
View Count: 793
[2017-05-04 23:07:59] |
N!co - Posts: 140 |
Hi, I have 15 chartbooks open each with 3 charts I would like to receive an alert when this candle pattern is formed http://www.sierrachart.com/image.php?Image=1493939023692.png how would i code this candle pattern ? and is it possible to recieve an alert when this pattern is formed on a symbol on a chartbook that is not opened thank you very much |
[2017-05-05 17:10:10] |
For this you will need to use the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=245#Color_Bar_Based_on_Alert_Condition You will need to create a formula to detect this. Once you set that up on one chart, you can link the Studies between charts with the Chart Linking feature: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChartLinking This is not supported: and is it possible to recieve an alert when this pattern is formed on a symbol on a chartbook that is not opened Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-05 17:11:47
