Date/Time: Sun, 08 Sep 2024 01:41:04 +0000
THE MENU OF THE DOM
View Count: 703
[2017-05-04 20:49:43] |
User80386 - Posts: 9 |
WHERE DID THE THE OPPORTUNITY TO CLEAN RECENT BID VOLUME AND RECENT ASK VOLUME? CURRENT TRADED BID VOLUME AND CURRENT TRADED ASK VOLUME? FROM THE MENU OF THE DOM. |
[2017-05-04 21:40:31] |
These commands have been moved to the Trade menu rather than the menu directly on the Trade Window. And you can add both keyboard shortcuts and Control Bar buttons for these commands. Refer to: Control Bar Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-04 21:41:09
