DTC Protocol Discussion Forum
- DTC Protocol Discussion Forum |
 - Search Board |
 - Control Panel |
 - View My Posts / Threads |
 - Direct Messages
Date/Time: Tue, 04 Nov 2025 15:12:36 +0000
Historical data connection issue in version 1536
View Count: 4278
|   [2017-05-04 20:47:13]     |
| onnb - Posts: 664 |
                I have an app that connects to the historical port. In 1536, the logon/connection fails. In 1529 the same app/code succeeds - it appears as if something broke in between  |
|   [2017-05-06 20:01:30]     |
| Queeq - Posts: 43 |
                Hi onnb, I wonder, do you use binary encoding?  |
|   [2017-05-07 04:11:02]     |
| onnb - Posts: 664 |
                Yes, binary encoding
|   [2017-05-14 04:15:07]     |
                You are referring to the Sierra Chart DTC protocol server for historical data. In 1536, the logon/connection fails. The historical data server is used extensively by sub instances of Sierra Chart which are started through File >> New Instance.  |
