Date/Time: Sat, 17 Oct 2026 05:35:11 +0000
Some charts getting wider as well as taller when I used Control+ Drag
View Count: 1027
[2017-05-04 18:36:53]
User40520 - Posts: 62
When I want to adjust the vertical height/depth of my charts using control+drag in the price field, half of my charts adjust without problem but the rest widen or squash up so the horizontal axis is active. All the settings are the same. Have I overloaded Sierra (lots of charts and calculations) or is there a solution?
[2017-05-04 18:51:18]
From our perspective, it is really hard to understand what you are describing.
We recommend you select Chart >> Reset Scales.
[2017-05-04 19:28:46]
"You can left click and drag your mouse pointer up and down in the Values Scale on the right side of the chart to move the chart up and down."
Some chart do as described above. The width of the candles and chart spacing doesn't change.
Others don't: the charts will squash up so I can't read them up or expand with huge wide candles on the horizontal instead of moving up and down on the vertical.
[2017-05-04 20:08:41]
This is because you have enabled Constant Relationship Scaling:
Chart Scale and Scale Adjusting: X & Y Constant Relationship Scaling
