Date/Time: Fri, 18 Oct 2024 05:52:39 +0000
status bar : waiting to reconnect ....
View Count: 1000
[2017-05-04 18:20:26] |
User430765 - Posts: 2 |
Why status bar is waiting to reconnecting ?????
[2017-05-04 18:35:54] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-04 19:04:29] |
Reading Internal Order ID file. | 2017-05-04 14:01:58 Reading Trade Orders file. | 2017-05-04 14:01:58 Reading Trade Positions file. | 2017-05-04 14:01:58 Software version: 1490 | 2017-05-04 14:01:58 Uses New Spreadsheets | 2017-05-04 14:01:58 Usage end date: 2017-06-04 | 2017-05-04 14:01:58 Enabled for: Advanced Features. | 2017-05-04 14:01:58 Enabled for: Advanced Features 2. | 2017-05-04 14:01:58 Enabled for: Sierra Chart Historical Data Service. | 2017-05-04 14:01:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-05-04 14:01:58 Current selected Data/Trading service: GAIN Capital/OEC | 2017-05-04 14:01:58 Chart Update Interval: 500 | 2017-05-04 14:01:58 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-05-04 14:01:58 2017-05-04 21:02:01 Local computer time | 2017-05-04 14:01:58 2017-05-04 19:02:01 Local computer time in UTC | 2017-05-04 14:01:58 2017-05-04 14:02:01 Local computer time in SC Time Zone | 2017-05-04 14:01:58 2017-05-04 19:01:57 Server time in UTC | 2017-05-04 14:01:58 Local computer UTC time and Server UTC time difference: 4 seconds. | 2017-05-04 14:01:58 Program path: C:\SierraChart\ | 2017-05-04 14:01:58 Data Files path: C:\SierraChart\Data\ | 2017-05-04 14:01:58 OS Version Number: 6.1 | 2017-05-04 14:01:58 Locale Setting: C | 2017-05-04 14:01:58 Checking for new symbol settings for oec | 2017-05-04 14:01:58 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2017-05-04 14:01:58 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2017-05-04 14:01:58 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2017-05-04 14:01:58 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2017-05-04 14:01:58 Symbol settings are up-to-date for oec | 2017-05-04 14:01:58 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:06 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:06 GAIN Capital FIX Trading socket (4) | Connected. | 2017-05-04 14:02:07 GAIN Capital FIX Trading socket (4) | Starting TLS 1.2 connection. | 2017-05-04 14:02:07 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2017-05-04 14:02:07 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2017-05-04 14:02:07 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:07 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2017-05-04 14:02:07 GAIN Capital FIX Trading socket (4) | SSL connection established. | 2017-05-04 14:02:07 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:07 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:07 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:07 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:07 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:07 GAIN Capital FIX Trading socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:07 GAIN Capital FIX Trading socket (4) | SSL has been shut down. | 2017-05-04 14:02:07 GAIN Capital FIX Trading socket (4) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:07 GAIN Capital FIX Trading socket (4) | Shutdown and closed. | 2017-05-04 14:02:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:07 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:07 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:07 GAIN Capital FAST Data socket (5) | Shutdown and closed. | 2017-05-04 14:02:07 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:07 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:07 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:07 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:11 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:11 GAIN Capital FIX Trading socket (6) | Connected. | 2017-05-04 14:02:11 GAIN Capital FIX Trading socket (6) | Starting TLS 1.2 connection. | 2017-05-04 14:02:11 GAIN Capital FIX Trading socket (6) | SSL connection established. | 2017-05-04 14:02:13 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:14 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:14 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:14 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:14 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:14 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:14 GAIN Capital FIX Trading socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:14 GAIN Capital FIX Trading socket (6) | SSL has been shut down. | 2017-05-04 14:02:14 GAIN Capital FIX Trading socket (6) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:14 GAIN Capital FIX Trading socket (6) | Shutdown and closed. | 2017-05-04 14:02:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:14 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:14 GAIN Capital FAST Data socket (7) | Shutdown and closed. | 2017-05-04 14:02:14 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:14 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:14 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:14 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | Connected. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | Starting TLS 1.2 connection. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | SSL connection established. | 2017-05-04 14:02:17 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:17 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:17 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:17 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:17 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | SSL has been shut down. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:17 GAIN Capital FIX Trading socket (8) | Shutdown and closed. | 2017-05-04 14:02:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:17 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:17 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:17 GAIN Capital FAST Data socket (9) | Shutdown and closed. | 2017-05-04 14:02:17 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:17 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:17 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:17 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:20 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:20 GAIN Capital FIX Trading socket (10) | Connected. | 2017-05-04 14:02:20 GAIN Capital FIX Trading socket (10) | Starting TLS 1.2 connection. | 2017-05-04 14:02:20 GAIN Capital FIX Trading socket (10) | SSL connection established. | 2017-05-04 14:02:21 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:21 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:21 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:21 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:21 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:21 GAIN Capital FIX Trading socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:21 GAIN Capital FIX Trading socket (10) | SSL has been shut down. | 2017-05-04 14:02:21 GAIN Capital FIX Trading socket (10) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:21 GAIN Capital FIX Trading socket (10) | Shutdown and closed. | 2017-05-04 14:02:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:21 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:21 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:21 GAIN Capital FAST Data socket (11) | Shutdown and closed. | 2017-05-04 14:02:21 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:21 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:21 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:21 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:24 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:24 GAIN Capital FIX Trading socket (12) | Connected. | 2017-05-04 14:02:24 GAIN Capital FIX Trading socket (12) | Starting TLS 1.2 connection. | 2017-05-04 14:02:24 GAIN Capital FIX Trading socket (12) | SSL connection established. | 2017-05-04 14:02:25 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:25 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:25 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:25 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:25 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:25 GAIN Capital FIX Trading socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:25 GAIN Capital FIX Trading socket (12) | SSL has been shut down. | 2017-05-04 14:02:25 GAIN Capital FIX Trading socket (12) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:25 GAIN Capital FIX Trading socket (12) | Shutdown and closed. | 2017-05-04 14:02:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:25 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:25 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:25 GAIN Capital FAST Data socket (13) | Shutdown and closed. | 2017-05-04 14:02:25 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:25 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:25 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:25 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:28 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:28 GAIN Capital FIX Trading socket (14) | Connected. | 2017-05-04 14:02:29 GAIN Capital FIX Trading socket (14) | Starting TLS 1.2 connection. | 2017-05-04 14:02:29 GAIN Capital FIX Trading socket (14) | SSL connection established. | 2017-05-04 14:02:29 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:29 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:29 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:29 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:29 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:29 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:29 GAIN Capital FIX Trading socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:29 GAIN Capital FIX Trading socket (14) | SSL has been shut down. | 2017-05-04 14:02:29 GAIN Capital FIX Trading socket (14) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:29 GAIN Capital FIX Trading socket (14) | Shutdown and closed. | 2017-05-04 14:02:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:29 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:29 GAIN Capital FAST Data socket (15) | Shutdown and closed. | 2017-05-04 14:02:29 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:29 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:29 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:29 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:32 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:32 GAIN Capital FIX Trading socket (16) | Connected. | 2017-05-04 14:02:32 GAIN Capital FIX Trading socket (16) | Starting TLS 1.2 connection. | 2017-05-04 14:02:32 GAIN Capital FIX Trading socket (16) | SSL connection established. | 2017-05-04 14:02:33 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:33 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:33 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:33 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:33 GAIN Capital FAST Data socket (17) | Connected. | 2017-05-04 14:02:33 GAIN Capital FAST Data: Sending the Hello message. | 2017-05-04 14:02:33 GAIN Capital FAST Data: Sending the Logon message. | 2017-05-04 14:02:34 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:34 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:34 GAIN Capital FIX Trading socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:34 GAIN Capital FIX Trading socket (16) | SSL has been shut down. | 2017-05-04 14:02:34 GAIN Capital FIX Trading socket (16) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:34 GAIN Capital FIX Trading socket (16) | Shutdown and closed. | 2017-05-04 14:02:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:34 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:34 GAIN Capital FAST Data: Sending a Logout message. | 2017-05-04 14:02:34 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:34 GAIN Capital FAST Data socket (17) | Closed. No error. | 2017-05-04 14:02:34 GAIN Capital FAST Data socket (17) | Shutdown and closed. | 2017-05-04 14:02:34 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2017-05-04 14:02:34 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:34 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | Connected. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | Starting TLS 1.2 connection. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | SSL connection established. | 2017-05-04 14:02:37 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:37 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:37 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:37 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:37 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:37 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | SSL has been shut down. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:37 GAIN Capital FIX Trading socket (18) | Shutdown and closed. | 2017-05-04 14:02:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:37 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:37 GAIN Capital FAST Data socket (19) | Shutdown and closed. | 2017-05-04 14:02:37 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:37 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:37 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:37 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:40 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:40 GAIN Capital FIX Trading socket (20) | Connected. | 2017-05-04 14:02:40 GAIN Capital FIX Trading socket (20) | Starting TLS 1.2 connection. | 2017-05-04 14:02:40 ESM7 1 Min #1 | Reloading chart. | 2017-05-04 14:02:44 Intraday data recording state for symbol ESM7 is set to download 'Pending'. | 2017-05-04 14:02:44 HD Request # 2 | Downloading Intraday chart data for ESM7 to the file ESM7.scid. Service: oec | 2017-05-04 14:02:44 HD Request # 2 | Download start date-time: 2017-05-03 17:49:58.000 | 2017-05-04 14:02:44 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-05-04 14:02:44 Socket (0) | Resolved address ds4.sierracharts.com to IP 192.81.56.146. | 2017-05-04 14:02:44 Socket (21) | Connected. | 2017-05-04 14:02:44 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-05-04 14:02:45 HD Request # 2 | Sending historical data logon request message. | 2017-05-04 14:02:45 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-05-03 17:49:58. Record interval: 0. Symbol: ESM7 | 2017-05-04 14:02:45 HD Request # 2 | Decompressing data. | 2017-05-04 14:02:45 HD Request # 2 | Receiving Intraday data for ESM7 starting at 2017-05-03 17:49:58 | 2017-05-04 14:02:46 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-05-03 17:50:49 | 2017-05-04 14:02:46 HD Request # 2 | Historical data for ESM7 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-05-04 14:02:47 Socket (21) | Shutdown and closed. | 2017-05-04 14:02:47 The network socket for historical data has been closed. | 2017-05-04 14:02:47 HD Request # 2 | Received 14231 records from 2017-05-03 17:49:58 to 2017-05-04 02:02:38 (8.2 hours) and wrote 14230 records for ESM7 | 2017-05-04 14:02:47 HD Request # 2 | Intraday download COMPLETE for ESM7. Completion time: 3s. Unique request ID: 1 | 2017-05-04 14:02:47 Removed historical data download ID 1 | 2017-05-04 14:02:47 GAIN Capital FIX Trading socket (20) | SSL connection established. | 2017-05-04 14:02:48 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:48 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:49 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:49 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:49 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:49 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:49 GAIN Capital FIX Trading socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:49 GAIN Capital FIX Trading socket (20) | SSL has been shut down. | 2017-05-04 14:02:49 GAIN Capital FIX Trading socket (20) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:49 GAIN Capital FIX Trading socket (20) | Shutdown and closed. | 2017-05-04 14:02:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:49 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:49 GAIN Capital FAST Data socket (22) | Shutdown and closed. | 2017-05-04 14:02:49 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:49 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:49 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:49 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:52 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:52 GAIN Capital FIX Trading socket (23) | Connected. | 2017-05-04 14:02:52 GAIN Capital FIX Trading socket (23) | Starting TLS 1.2 connection. | 2017-05-04 14:02:52 GAIN Capital FIX Trading socket (23) | SSL connection established. | 2017-05-04 14:02:53 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:54 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:02:54 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:02:54 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:02:54 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:02:54 GAIN Capital FIX Trading socket (23) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:02:54 GAIN Capital FIX Trading socket (23) | SSL has been shut down. | 2017-05-04 14:02:54 GAIN Capital FIX Trading socket (23) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:02:54 GAIN Capital FIX Trading socket (23) | Shutdown and closed. | 2017-05-04 14:02:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:02:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:02:54 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:02:54 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:54 GAIN Capital FAST Data socket (24) | Shutdown and closed. | 2017-05-04 14:02:54 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:02:54 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:02:54 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:02:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:02:54 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:02:57 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:02:57 GAIN Capital FIX Trading socket (25) | Connected. | 2017-05-04 14:02:57 GAIN Capital FIX Trading socket (25) | Starting TLS 1.2 connection. | 2017-05-04 14:02:57 GAIN Capital FIX Trading socket (25) | SSL connection established. | 2017-05-04 14:02:59 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:02:59 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:00 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:00 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:00 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:00 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:00 GAIN Capital FIX Trading socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:00 GAIN Capital FIX Trading socket (25) | SSL has been shut down. | 2017-05-04 14:03:00 GAIN Capital FIX Trading socket (25) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:00 GAIN Capital FIX Trading socket (25) | Shutdown and closed. | 2017-05-04 14:03:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:00 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:00 GAIN Capital FAST Data socket (26) | Shutdown and closed. | 2017-05-04 14:03:00 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:00 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:00 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:00 ESM7 5 Min #1 | Reloading chart. | 2017-05-04 14:03:00 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | Connected. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | Starting TLS 1.2 connection. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | SSL connection established. | 2017-05-04 14:03:03 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:03 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:03 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:03 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:03 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:03 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | SSL has been shut down. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:03 GAIN Capital FIX Trading socket (27) | Shutdown and closed. | 2017-05-04 14:03:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:03 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:03 GAIN Capital FAST Data socket (28) | Shutdown and closed. | 2017-05-04 14:03:03 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:03 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:03 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:03 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:06 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:06 GAIN Capital FIX Trading socket (29) | Connected. | 2017-05-04 14:03:07 GAIN Capital FIX Trading socket (29) | Starting TLS 1.2 connection. | 2017-05-04 14:03:07 GAIN Capital FIX Trading socket (29) | SSL connection established. | 2017-05-04 14:03:07 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:07 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:07 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:07 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:07 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:07 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:07 GAIN Capital FIX Trading socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:07 GAIN Capital FIX Trading socket (29) | SSL has been shut down. | 2017-05-04 14:03:07 GAIN Capital FIX Trading socket (29) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:07 GAIN Capital FIX Trading socket (29) | Shutdown and closed. | 2017-05-04 14:03:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:07 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:07 GAIN Capital FAST Data socket (30) | Shutdown and closed. | 2017-05-04 14:03:07 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:07 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:07 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:07 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:10 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:10 GAIN Capital FIX Trading socket (31) | Connected. | 2017-05-04 14:03:10 GAIN Capital FIX Trading socket (31) | Starting TLS 1.2 connection. | 2017-05-04 14:03:10 GAIN Capital FIX Trading socket (31) | SSL connection established. | 2017-05-04 14:03:11 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:11 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:11 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:11 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:11 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:11 GAIN Capital FIX Trading socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:11 GAIN Capital FIX Trading socket (31) | SSL has been shut down. | 2017-05-04 14:03:11 GAIN Capital FIX Trading socket (31) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:11 GAIN Capital FIX Trading socket (31) | Shutdown and closed. | 2017-05-04 14:03:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:11 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:11 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:11 GAIN Capital FAST Data socket (32) | Shutdown and closed. | 2017-05-04 14:03:11 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:11 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:11 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:11 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:11 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:14 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:14 GAIN Capital FIX Trading socket (33) | Connected. | 2017-05-04 14:03:15 GAIN Capital FIX Trading socket (33) | Starting TLS 1.2 connection. | 2017-05-04 14:03:15 GAIN Capital FIX Trading socket (33) | SSL connection established. | 2017-05-04 14:03:15 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:15 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:15 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:15 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:15 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:15 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:15 GAIN Capital FIX Trading socket (33) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:15 GAIN Capital FIX Trading socket (33) | SSL has been shut down. | 2017-05-04 14:03:15 GAIN Capital FIX Trading socket (33) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:15 GAIN Capital FIX Trading socket (33) | Shutdown and closed. | 2017-05-04 14:03:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:15 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:15 GAIN Capital FAST Data socket (34) | Shutdown and closed. | 2017-05-04 14:03:15 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:15 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:15 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:15 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:18 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:18 GAIN Capital FIX Trading socket (35) | Connected. | 2017-05-04 14:03:18 GAIN Capital FIX Trading socket (35) | Starting TLS 1.2 connection. | 2017-05-04 14:03:18 GAIN Capital FIX Trading socket (35) | SSL connection established. | 2017-05-04 14:03:19 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:19 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:19 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:19 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:19 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:19 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:19 GAIN Capital FIX Trading socket (35) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:19 GAIN Capital FIX Trading socket (35) | SSL has been shut down. | 2017-05-04 14:03:19 GAIN Capital FIX Trading socket (35) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:19 GAIN Capital FIX Trading socket (35) | Shutdown and closed. | 2017-05-04 14:03:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:19 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:19 GAIN Capital FAST Data socket (36) | Shutdown and closed. | 2017-05-04 14:03:19 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:19 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:19 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:19 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:22 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:22 GAIN Capital FIX Trading socket (37) | Connected. | 2017-05-04 14:03:22 GAIN Capital FIX Trading socket (37) | Starting TLS 1.2 connection. | 2017-05-04 14:03:22 GAIN Capital FIX Trading socket (37) | SSL connection established. | 2017-05-04 14:03:22 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:23 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:23 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:23 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:23 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:23 GAIN Capital FIX Trading socket (37) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:23 GAIN Capital FIX Trading socket (37) | SSL has been shut down. | 2017-05-04 14:03:23 GAIN Capital FIX Trading socket (37) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:23 GAIN Capital FIX Trading socket (37) | Shutdown and closed. | 2017-05-04 14:03:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:23 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:23 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:23 GAIN Capital FAST Data socket (38) | Shutdown and closed. | 2017-05-04 14:03:23 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:23 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:23 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:23 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:26 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:26 GAIN Capital FIX Trading socket (39) | Connected. | 2017-05-04 14:03:26 GAIN Capital FIX Trading socket (39) | Starting TLS 1.2 connection. | 2017-05-04 14:03:26 GAIN Capital FIX Trading socket (39) | SSL connection established. | 2017-05-04 14:03:27 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:27 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:27 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:27 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:27 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:27 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:27 GAIN Capital FIX Trading socket (39) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:27 GAIN Capital FIX Trading socket (39) | SSL has been shut down. | 2017-05-04 14:03:27 GAIN Capital FIX Trading socket (39) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:27 GAIN Capital FIX Trading socket (39) | Shutdown and closed. | 2017-05-04 14:03:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:27 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:27 GAIN Capital FAST Data socket (40) | Shutdown and closed. | 2017-05-04 14:03:27 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:27 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:27 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:27 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:30 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:30 GAIN Capital FIX Trading socket (41) | Connected. | 2017-05-04 14:03:30 GAIN Capital FIX Trading socket (41) | Starting TLS 1.2 connection. | 2017-05-04 14:03:30 GAIN Capital FIX Trading socket (41) | SSL connection established. | 2017-05-04 14:03:30 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:31 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:31 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:31 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:31 GAIN Capital FAST Data socket (42) | Connected. | 2017-05-04 14:03:31 GAIN Capital FAST Data: Sending the Hello message. | 2017-05-04 14:03:31 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:31 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:31 GAIN Capital FIX Trading socket (41) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:31 GAIN Capital FIX Trading socket (41) | SSL has been shut down. | 2017-05-04 14:03:31 GAIN Capital FIX Trading socket (41) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:31 GAIN Capital FIX Trading socket (41) | Shutdown and closed. | 2017-05-04 14:03:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:31 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:31 GAIN Capital FAST Data: Sending a Logout message. | 2017-05-04 14:03:31 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:31 GAIN Capital FAST Data: Sending the Logon message. | 2017-05-04 14:03:32 GAIN Capital FAST Data socket (42) | Closed. No error. | 2017-05-04 14:03:32 GAIN Capital FAST Data socket (42) | Shutdown and closed. | 2017-05-04 14:03:32 GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2017-05-04 14:03:32 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:32 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | Connected. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | Starting TLS 1.2 connection. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | SSL connection established. | 2017-05-04 14:03:35 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:35 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:35 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:35 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:35 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | SSL has been shut down. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:35 GAIN Capital FIX Trading socket (43) | Shutdown and closed. | 2017-05-04 14:03:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:35 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:35 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:35 GAIN Capital FAST Data socket (44) | Shutdown and closed. | 2017-05-04 14:03:35 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:35 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:35 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:35 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:38 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:38 GAIN Capital FIX Trading socket (45) | Connected. | 2017-05-04 14:03:39 GAIN Capital FIX Trading socket (45) | Starting TLS 1.2 connection. | 2017-05-04 14:03:39 GAIN Capital FIX Trading socket (45) | SSL connection established. | 2017-05-04 14:03:39 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:39 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:39 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:39 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:39 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:39 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:39 GAIN Capital FIX Trading socket (45) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:39 GAIN Capital FIX Trading socket (45) | SSL has been shut down. | 2017-05-04 14:03:39 GAIN Capital FIX Trading socket (45) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:39 GAIN Capital FIX Trading socket (45) | Shutdown and closed. | 2017-05-04 14:03:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:39 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:39 GAIN Capital FAST Data socket (46) | Shutdown and closed. | 2017-05-04 14:03:39 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:39 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:39 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:39 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:42 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:42 GAIN Capital FIX Trading socket (47) | Connected. | 2017-05-04 14:03:42 GAIN Capital FIX Trading socket (47) | Starting TLS 1.2 connection. | 2017-05-04 14:03:42 GAIN Capital FIX Trading socket (47) | SSL connection established. | 2017-05-04 14:03:43 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:43 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:43 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:43 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:43 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:43 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:43 GAIN Capital FIX Trading socket (47) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:43 GAIN Capital FIX Trading socket (47) | SSL has been shut down. | 2017-05-04 14:03:43 GAIN Capital FIX Trading socket (47) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:43 GAIN Capital FIX Trading socket (47) | Shutdown and closed. | 2017-05-04 14:03:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:43 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:43 GAIN Capital FAST Data socket (48) | Shutdown and closed. | 2017-05-04 14:03:43 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:43 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:43 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:43 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:46 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:46 GAIN Capital FIX Trading socket (49) | Connected. | 2017-05-04 14:03:46 GAIN Capital FIX Trading socket (49) | Starting TLS 1.2 connection. | 2017-05-04 14:03:46 GAIN Capital FIX Trading socket (49) | SSL connection established. | 2017-05-04 14:03:46 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:47 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:47 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:47 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:47 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:47 GAIN Capital FIX Trading socket (49) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:47 GAIN Capital FIX Trading socket (49) | SSL has been shut down. | 2017-05-04 14:03:47 GAIN Capital FIX Trading socket (49) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:47 GAIN Capital FIX Trading socket (49) | Shutdown and closed. | 2017-05-04 14:03:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:47 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:47 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:47 GAIN Capital FAST Data socket (50) | Shutdown and closed. | 2017-05-04 14:03:47 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:47 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:47 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:47 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | Connected. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | Starting TLS 1.2 connection. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | SSL connection established. | 2017-05-04 14:03:50 GAIN Capital FIX Trading: Sending the Logon message. | 2017-05-04 14:03:50 GAIN Capital FIX Trading | Connected to trading server. | 2017-05-04 14:03:50 GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2017-05-04 14:03:50 GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:50 GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | SSL shutdown indicates not able to send 'close notify'. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | SSL has been shut down. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | SSL object has been freed. SSL state is now disconnected. | 2017-05-04 14:03:50 GAIN Capital FIX Trading socket (51) | Shutdown and closed. | 2017-05-04 14:03:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-05-04 14:03:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-05-04 14:03:50 GAIN Capital/OEC | Disconnected from the trading server. | 2017-05-04 14:03:50 GAIN Capital FAST Data socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2017-05-04 14:03:50 GAIN Capital FAST Data socket (52) | Shutdown and closed. | 2017-05-04 14:03:50 GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2017-05-04 14:03:50 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2017-05-04 14:03:50 GAIN Capital/OEC | Disconnected. | 2017-05-04 14:03:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-05-04 14:03:50 |
[2017-05-04 19:51:14] |
This is the relevant message: GAIN Capital FIX Trading: Received a Logout message. Text = This software is not permitted to logon | 2017-05-04 14:03:50 Go to this page to enable Sierra Chart to be able to use your Gain Capital account: https://myaccount.gainfutures.com/Software/ThirdParty Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-04 19:52:15
