Date/Time: Sun, 08 Sep 2024 01:55:16 +0000
Can you get Volume per Bar and Tick Chart options on the general control bar?
View Count: 663
[2017-05-04 17:59:38] |
User772556 - Posts: 21 |
Right now I can quickly select between different time bars on the control bar but to switch to tick chart or volume chart i have to go to chart setting. Any way to add those to the control bar?
[2017-05-04 18:22:11] |
Refer to the instructions here: Control Bar: Custom Buttons for Intraday Chart Bar Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-04 18:30:24] |
Thank you.
