Date/Time: Sun, 08 Sep 2024 01:48:57 +0000
How to increase login limit?
View Count: 669
[2017-05-04 17:02:14] |
User44790 - Posts: 20 |
Hello I would like to increase my Login limit per PC up to 1 more....... How much is default? I think 2 or 3....... so if 2 i would like to increase to 3 or if default is 3 i would like to increase to 4. Thank you Jaroslav |
[2017-05-04 17:05:32] |
The limit is 2 and you can increase this up to 5. You can do this here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Let us know if you need help or there is any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-04 17:05:55
