Date/Time: Wed, 23 Sep 2026 15:05:55 +0000
TPO for only last evening session
View Count: 1840
| [2017-05-04 15:00:33] |
| User968625 - Posts: 260 |
for the TPO study, is there anyway to have only last evening session and not all of them. It is the one that is relevant one to check evening inventory. when having all of evening session then it make the chart larger then needs to be and confusing. this how the Jim Dalton and main market profile traders use it |
| [2017-05-04 17:11:57] |
We will see if we can add this capability today. It currently does not exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-05-04 17:15:30] |
Thank you very much.
| [2017-05-04 21:45:45] |
This has been implemented and will be out tomorrow. The name of the new TPO Profile Chart study Input is: Exclude Evening Session Profiles Except For Last Day We have had many requests for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-05-05 00:46:23] |
| [2017-05-05 20:10:02] |
I have checked and it is not there. Pls let me know, post here, when it is out. Thanks again
| [2017-05-05 20:34:57] |
This is out. It is in the latest prerelease. Update following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-07-30 10:57:36] |
| User992529 - Posts: 32 |
The functionality for this doesn't seem to work properly when keeping SC open more than 24h. The next evening session gets drawn along with the previous one being left there - in total two TPO evening sessions. In order to show only one evening session one has to press the "RAR" button. SC should re-draw automatically at start of new evening session.
| [2019-07-30 11:05:18] |
Yes this is true. You do have to recalculate the chart with Chart >> Recalculate. That has to be manually done. You just need a recalculation and not a reload.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-30 11:06:24
| [2019-07-30 12:01:17] |
I think there are many times that we need to recalculate. the study "Chart Recalculation-period" helps but can we just add start-time and end time to this Recalculation study. this will help many of us and make it easier on PC resources. (for example in this last case of the TPO then we can set up a recalculation at a certain time.
| [2019-11-20 12:51:49] |
| User467974 - Posts: 2 |
I am having problems with this functionality. Maybe my settings have something wrong. When I exclude the evening profiles, sometimes one of my regular market hour profiles changes. You can see the image, when I exclude I got single D's, and when I have Evening session, I do not. This is from 15 november 2019 on ES.
Attachment Deleted. |
