Date/Time: Tue, 04 Nov 2025 18:43:24 +0000
how much is the monthly fee ?
View Count: 6246
| [2017-05-04 03:56:47] |
| user - Posts: 78 |
hi there, I want to use your platform to get the real time data for mini- hang seng index futures, maay you please help me to calculate how much should I pay for each month? Thanks! |
| [2017-05-04 05:20:07] |
You will need Sierra Chart Usage Time, for pricing refer to this page: Description of Service Packages and Pricing You will also need to activate the Sierra Chart Real-Time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Refer to the pricing here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing As you are in Hong Kong, to be able to activate the Hong Kong Futures Exchange, you need to contact Mr Rickey Cheung. http://www.rc3200.com. 852-91797856. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-04 05:20:40
| [2017-05-04 05:32:08] |
| user - Posts: 78 |
it is too complicated, can you just tell me the exact amount i have to pay for each month?!
| [2017-05-04 05:41:35] |
As you are in Hong Kong, to be able to activate the real-time Hong Kong Futures Exchange, you need to contact Mr Rickey Cheung. http://www.rc3200.com or 852-91797856 and join their education program. The real-time Hong Kong futures data provided by Sierra Chart is only available through that program when using Sierra Chart if you are in Hong Kong. Otherwise real-time Hong Kong futures data is not included. So the pricing at this moment is not the main question. The above is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-04 05:41:45
| [2017-05-04 05:46:14] |
| user - Posts: 78 |
you mean my account is registered in hong kong? how about my person is not in hk? |
| [2017-05-04 05:51:07] |
If you are not in Hong Kong or China this limitation does not apply.
| [2017-05-04 05:58:19] |
| user - Posts: 78 |
but how do you know if my body is in hong kong or china?
| [2017-05-04 06:00:31] |
This is based on your IP address which we currently see in Hong Kong.
| [2017-05-04 06:08:33] |
| user - Posts: 78 |
okay, then how about I sometimes in hong kong , sometimes oversea?
| [2017-05-04 06:14:09] |
This should be all right. Your IP will need to be outside Hong Kong though when activating the service. The cost of Sierra Chart is 24 USD per month for the standard service package. The data feed is 25 or 35USD per month depending upon how many symbols you need to track. Below are the Hong Kong futures exchange fees: Hong Kong Futures Exchange: Price 5.25 USD/month. Hong Kong Futures Exchange with Market Depth: Price 12.75 USD/month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-05-04 06:30:58] |
| user - Posts: 78 |
thanks so much for your explanation
