Date/Time: Sun, 08 Sep 2024 01:56:39 +0000
Zigzag extesion lines
View Count: 620
[2017-05-03 19:35:37] |
User132748 - Posts: 159 |
Is there any possibility to color Zigzag extension lines with 2 instead of 1 color? (Highs and Lows with different colors). BR |
[2017-05-04 01:10:51] |
Yes we can do that. This will be supported in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
