Date/Time: Sun, 08 Sep 2024 01:45:51 +0000
Displaying Separate Profiles For Day and Evening Sessions...
View Count: 2032
[2017-05-03 16:46:39] |
User629089 - Posts: 93 |
Hi Support, The Sierra documentation for the topic, "Displaying Separate Profiles For Day and Evening Sessions" explains how to do that for Volume Profile. There's a picture in the documentation that shows both volume and market profile (TPO's) being separated between and day and eve sessions. The VP works but when adding the MP, it doesn't work, only showing one profile for the 24hr/ETH session. I've tried adding the MP first, and then VP which doesn't work. I then added the MP after the VP is set up properly and that changes it to one 24hr/ETH profile only. Any ideas on how to correct this? Attached should be a VP chart only which looks good and the same chart with the MP (TPO's) added that doesn't separate RTH and ETH. http://www.sierrachart.com/image.php?Image=1493829515915.png http://www.sierrachart.com/image.php?Image=1493829307296.png Thanks |
[2017-05-03 17:31:33] |
Refer to: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#DayEveningSeparateProfiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
