Date/Time: Tue, 14 Jan 2025 11:18:56 +0000
DEMO extension
View Count: 1011
[2017-05-03 16:15:33] |
User747491 - Posts: 4 |
Hi Sierra, I would like to request for an extention for my DEMO for 2 weeks. Username: shui sing
[2017-05-03 16:55:32] |
Sierra Chart - Max - Posts: 5778 |
Your account has been activated and/or reset. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2017-05-04 14:41:55] |
Thank you Max. Appreciate
[2017-05-14 07:54:35] |
Dear Sierra, my demo account has stopped working. However I can do the funding only on May 23rd (9 more days). If you could please do the extension so that I can continue the learning.
[2017-05-14 21:00:13] |
Your Sierra Chart account is active until 2017-06-02. It sounds as though your Rithmic demo account has expired and that is not anything we have control over. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-14 22:53:23] |
I see. I will check with my broker. Thanks alot Sierra
