Date/Time: Sat, 31 Oct 2026 04:55:20 +0000
the middle in between previous day's close and today's day open?
View Count: 1373
| [2017-05-03 15:57:16] |
| User252419 - Posts: 236 |
How can I plot halfgap, so the middle between previous day close and today open? Thank u |
| [2017-05-03 17:37:42] |
This can be done by using two instances of the Daily OHLC study: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=137#Daily_OHLC One of them referencing the current day and another one referencing the prior day. You can then use the Study Subgraphs Average study to calculate the average that you want. Refer to: http://www.sierrachart.com/index.php?page=doc/ArithmeticStudies.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
