Date/Time: Mon, 05 Oct 2026 04:42:04 +0000
Request for disable the automatically renew
View Count: 1352
[2017-05-03 14:18:34]
User712241 - Posts: 1
I would like to don't allow the automatically renew, is it possible ? if yes , how ?
Best Regards,
Angelo
[2017-05-03 16:54:06]
We will do this for you.
[2017-05-03 16:59:25]
Sierra Chart - Max - Posts: 5972
Usage time will only renew if you have a sufficient Services Balance for said renewal. So you can just top up your Services Balance when you want to renew your Usage Time.
Or you can just disable the Renewal under "Choose Usage Time Service Package" here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#1
Sierra Chart Support
