Date/Time: Fri, 18 Oct 2024 06:07:52 +0000
[User Discussion] - spreadsheet?
View Count: 706
[2017-05-03 12:51:19] |
User20450 - Posts: 330 |
is there a easier way to start a spreadsheet , i open spreadsheet study , then have to save it for it to close then reopen it , also why dont new spreads have blank cells , they seem to keep all the data from old spread even as a new spread , thanks
[2017-05-03 16:30:06] |
then have to save it for it to close then reopen it , This makes no sense to us whatsoever. We do not know what you are saying., also why dont new spreads have blank cells , they seem to keep all the data from old spread even as a new spread You must have specified the same Spreadsheet Name in the Spreadsheet study. And of course, the Spreadsheet is going to contain data from the chart. Why on earth would it be blank? You need to follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/UsingTheSpreadsheetStudy.php Follow them step-by-step and exactly. There is no reason for this post to begin with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-03 17:57:17] |
im aware how to use the spread i have been using for some time now , im just asking a simple question , maybe there is issue with new update or something i have no idea ,. all im saying is when i open a spreadsheet and name it and attach it to sheet to chart , i get prev formulas on the new spread , so im simply asking if there is something wrong , but ill figure it out , thanks for the help . |
