Date/Time: Wed, 15 Jan 2025 06:36:52 +0000
Omptimus, Amp and Rithmic
View Count: 1297
[2017-05-03 12:24:58]
grantx - Posts: 244
Whats your view on using Optimus with AMP and Rithmic or CQG?
I get so many conflicting opinions that I would like to ask you, since you would know what the best setup is with your platform.
[2017-05-03 15:18:17]
We recommend using CQG.
[2017-06-09 22:11:34]
User521791 - Posts: 12
Hello can you explain why you recommend CQG over Rithmic?
[2017-06-09 22:15:29]
When there are connectivity problems, it is much easier to understand what the problem is with CQG compared to Rithmic.
There is also not a separate process involved with connecting to Rithmic which is necessary because it uses an API component. More about that is here:
Sierra Chart Does not Support External Service API Components
So re-connections to CQG are much faster than Rithmic.
Date Time Of Last Edit: 2017-06-09 22:16:28
