Date/Time: Fri, 18 Oct 2024 05:54:43 +0000
Dom's not always showing P/L when flat
View Count: 710
[2017-05-03 11:54:47] |
User554317 - Posts: 59 |
Some Dom windows don't seem to show me my P/L when I'm flat and I get the feeling that some Dom's sometimes do and sometimes don't. Where can I correct this? Thank you. |
[2017-05-03 17:06:55] |
If you are referring to the Daily Profit/Loss value, then refer to: http://www.sierrachart.com/index.php?page=doc/DailyProfitLossValue.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-04 04:06:15] |
I'm not sure this is it. I mean in the Net field, called N: sometimes I close trades for profit or loss but the N: doesn't actually display anything other than 0.00C |
[2017-05-04 04:40:53] |
This is the relevant documentation for that field as well: http://www.sierrachart.com/index.php?page=doc/DailyProfitLossValue.html Since the Net Profit/Loss includes the Daily Profit/Loss plus the Open Profit/Loss. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-04 04:41:38
