Date/Time: Fri, 18 Oct 2024 05:47:47 +0000
How to remove an element from chart header
View Count: 1524
[2017-05-03 08:25:33] |
grantx - Posts: 244 |
How do I remove the '[Sim] Trade' text from chart header? See image. http://www.sierrachart.com/image.php?Image=1493799770415.png Ive already read through your help file but I cant find an explanation there: Working With Charts: Chart Numbers |
[2017-05-03 17:35:26] |
You need to disable: http://www.sierrachart.com/index.php?page=doc/TradeMenu.html#ChartTradeModeOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
