Date/Time: Mon, 13 Jan 2025 16:57:21 +0000
RTH HOURS ONLY ISSUE
View Count: 1067
[2017-05-03 04:40:10] |
Trader&Hunter - Posts: 131 |
i have a spreadsheet trading system and I want it on RTH hours only. I am watching 10 markets and all my markets stop showing anything after 1330 time frame. any reason for this?
[2017-05-03 04:44:23] |
We are not understanding this. Here is the documentation for chart Session Times: Chart Session Times and all my markets stop showing anything after 1330 time frame. any reason for this? You would know best because you know how you set the Session Times. We do not know the answer to this.
[2017-05-03 04:51:03] |
I have my session times from 07:00:00 to 14:00:00. and it still doesn't show me anything after 1330ish as you see on screenshot
Capture.PNG / V - Attached On 2017-05-03 04:49:36 UTC - Size: 41.6 KB - 253 views Capture1.PNG / V - Attached On 2017-05-03 04:50:08 UTC - Size: 40.12 KB - 262 views Attachment Deleted. |
[2017-05-03 05:19:43] |
You must set the chart bars to 1 minute per bar in order for you to even be able to analyze this properly. It is impossible for you to come to the conclusion you have with a chart like that which uses manipulated variable timeframe bars (Flex Renko bars). Also, we do see trades at 14:00:53 in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-03 05:34:35
