Date/Time: Mon, 13 Jan 2025 16:43:04 +0000
ACSIL, convert to base currency
View Count: 970
[2017-05-02 21:37:12] |
phaedonk - Posts: 352 |
Is there a function that converts the currency value per tick to the user's base currency? I'm building a position sizing study and would like to convert USD,JPY, etc to EUR. I'd guess there must be something as SC converts charts P&L to the user selected currency. |
[2017-05-02 22:54:17] |
This is not supported in ACSIL. And we are not in a position to add this anytime soon.
[2017-05-03 01:53:20] |
I see. How about an easy way to access fx rates (from SC forex data) without having a chart open? Or, less ideal, accessing a quoteboard. Edit: By using sc.GetBasicSymbolData(),I guess. Date Time Of Last Edit: 2017-05-03 02:06:05
[2017-05-03 03:39:00] |
Yes, use that function. Here is the documentation: sc.GetBasicSymbolData() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
