Date/Time: Mon, 13 Jan 2025 17:14:55 +0000
Is it possible to make the time and sales window a part of the chartbook?
View Count: 623
[2017-05-02 19:07:27] |
User772556 - Posts: 21 |
Right now its separate floating window but I want it to be part of the chartbook. Is this possible?
[2017-05-02 19:13:04] |
No, this is not supported.
