Date/Time: Mon, 13 Jan 2025 16:44:27 +0000
forex data
View Count: 685
[2017-05-02 17:17:49] |
User38857 - Posts: 14 |
can you please tell me how to get only bid data chart eur/jpy instead mid chart even if open -bid chart still it is only mid chart thank you |
[2017-05-03 04:19:51] |
You do need to use the -BID suffix, but the downloaded historical data will still be based on the Bid Ask average. Refer to: Data Recording Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
