Date/Time: Mon, 13 Jan 2025 14:36:31 +0000
Custom Study - command / button or event
View Count: 914
[2017-05-02 14:37:58] |
User612903 - Posts: 51 |
Hi, Is there a way to have my custom study to respond to a special button / command ? For example when you press a button or when you press an icon in sierra, the custom study do something ? Regards |
[2017-05-02 14:44:33] |
Yes. Refer to: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events You can use Control Bar buttons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
