Date/Time: Mon, 13 Jan 2025 17:17:57 +0000
TPO Value Lines
View Count: 643
[2017-05-02 14:07:40] |
Dennis B. - Posts: 272 |
Is there a way to just have the previous day and going backward and not have the current day levels on the chart.I'm referring to the TPO Value Area Lines study.
[2017-05-02 16:56:42] |
You need to use the Reference n Period Back Input with the study to reference a prior period. There still will be lines drawn on the current day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-02 17:00:52] |
Maybe a newer version could clear that up, very annoying IMO.
