Date/Time: Mon, 13 Jan 2025 17:05:43 +0000
Priceline and historical trade markers on chart
View Count: 2073
[2017-05-02 12:47:51] |
grantx - Posts: 244 |
1. Is there a priceline indicator? Basically a horizontal line across the chart that moves with current price? 2. Does chart have a function that shows historical trades? Little markers/arrows showing entry and exit points? 3. How do I save an image of the DOM window only? Thank you. |
[2017-05-02 16:41:26] |
http://www.sierrachart.com/image.php?Image=1493743171566.png Ok I have worked out how to show the trade markers. How do I change the text and colour of the background of the marker so that I can see the text? Thanks |
[2017-05-02 16:52:48] |
1. Refer to: http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=123#Current_Price_Line 2. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#DisplayingOrderFills 3. Refer to: http://www.sierrachart.com/index.php?page=doc/Image_to_Server.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
