Date/Time: Mon, 13 Jan 2025 16:55:16 +0000
Same settings different charting.... why?
View Count: 686
[2017-05-02 11:06:22] |
User731133 - Posts: 27 |
How is it possible to have the same indicator settings same data feed but a different charting on the same product?If you look between 10:01 to 10:07 on the pictures that i attached you can see that the green indicator draw a different line on the chart why? Regards Alessandro |
Chart 1.jpg / V - Attached On 2017-05-02 10:47:49 UTC - Size: 120.56 KB - 256 views Chart 2.jpg / V - Attached On 2017-05-02 10:48:05 UTC - Size: 241.88 KB - 259 views |
[2017-05-02 16:32:27] |
When posting an image of a chart, you must follow these instructions only: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Repost the chart image following those instructions. There must be differences with the underlying chart bar data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-02 19:08:09] |
No The underlying chart bar data is the same but the version of the SC is different here are the screenshot that you request http://www.sierrachart.com/image.php?Image=1493745930998.png http://www.sierrachart.com/image.php?Image=1493750731650.png |
[2017-05-03 05:16:59] |
At this point you must follow this procedure: Chart Studies: Resolving Study Differences The version of Sierra Chart might matter, but it is not likely. From what we can tell, there are differences in the underlying data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
