Date/Time: Mon, 13 Jan 2025 14:32:45 +0000
Zig Zag new points hidden
View Count: 669
[2017-05-01 18:42:57] |
User99934 - Posts: 227 |
Hi, When using the zig zag indicator and a new point is created, I can't see it and the label until some time has gone by. I have to manually scroll forward the chart each time. I have tried numerous adjustments but unable to figure out. Thanks. |
[2017-05-01 19:26:52] |
We are not understanding this. But maybe you want to add some more space on the right side of the chart. Refer to: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#FillSpace Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-01 19:44:51] |
The lock fill space command worked.
