Date/Time: Thu, 16 Jan 2025 01:17:05 +0000
Center Study around Zero..
View Count: 791
[2017-05-01 16:11:07]
User316362 - Posts: 210
I'm having trouble centering a Study around zero. The values of the study i want to auto scale around zero (zero in the middle of the study range always). But the scale of the study can change depending on plus/minus values in scope.
Is there a way to do this?
[2017-05-01 16:49:15]
You could try using a User Defined scale:
http://www.sierrachart.com/index.php?page=doc/Scaling.html
[2017-10-02 16:15:00]
Just a thought.... We often have charts that pre-defining a range just to center the "Zero" on the chart is not reasonable.
As a result I had to code determination of the visible range and setting the range to the larger of the high low to make this work.
This seems to me to perhaps be a common issue.
It would be nice to have this built into the settings similar to the "automatic Zero-Based" setting. Perhaps create a "Automatic Zero-Centered" setting that creates the max range (based on visible chart) with Zero centered in the chart.
This certainly would benefit many of the indexes, market stats , studies etc
Date Time Of Last Edit: 2017-10-02 16:20:45
[2017-10-02 17:41:19]
OK, we will look into this.
