Date/Time: Mon, 13 Jan 2025 14:38:18 +0000
Symbol HG fails to update
View Count: 761
[2017-05-01 15:57:54]
User94740 - Posts: 333
I have SC real-time and configured for 10 symbols. I only have eight open and HG fails to updated although the others are fine. I also received a message while rolling over the contract, "symbol is unknown."
[2017-05-01 16:21:57]
Understand when you are working with a low symbol limit like that, you are going to run into problems like this.
Assuming that is the reason but most likely.
You need to update to the higher symbol level. Also try reconnecting to the data feed:
http://www.sierrachart.com/index.php?page=doc/FileMenu.html#ProcedureToReconnect
We are not going to do any kind of extensive analysis for you on this matter.
Date Time Of Last Edit: 2017-05-01 16:22:59
[2017-05-01 16:27:07]
disconnected and reconnected worked
[2017-05-01 16:37:10]
OK most likely due to the rollover and the increased number of symbols.
