Date/Time: Mon, 13 Jan 2025 14:35:13 +0000
CTS support
View Count: 570
[2017-05-01 14:26:28] |
User36492 - Posts: 48 |
I keep getting notifications about CTS support. I use Interactive Brokers. Am I correct in assuming that IB customers can't use this option?
[2017-05-01 17:29:39] |
You can disregard that notice. It is just about a new low-cost connection model Sierra Chart has to CTS. Interactive Brokers users cannot use CTS. You would have to be with a different broker supporting CTS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-01 17:30:05
