Date/Time: Mon, 13 Jan 2025 14:37:51 +0000
Renko brick size
View Count: 1281
[2017-05-01 10:10:25] |
grantx - Posts: 244 |
I am using Renko bars with your Ichimoku study. I would like to know how to set the renko bars to 1 tick in size, updated every minute (or 5 minutes whatever I choose) http://www.sierrachart.com/image.php?Image=1493633272426.png Thank you. |
[2017-05-01 18:21:45] |
Follow through the instructions on this page: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html You just need to set the size to 1. updated every minute (or 5 minutes whatever I choose)
There is no way to control this.
