Date/Time: Sun, 19 May 2024 06:24:08 +0000
TPO Single Prints
View Count: 6356
[2024-02-09 00:59:07] |
jmftattoo - Posts: 76 |
@ sierra dev team, the singles should not be deleted fully until the entire zone is back filled with new letters. See example, there is a single zone that was launched, and price started to move back down into it, but fell short of completely moving through the single zone. the high of the singles zone should move down to represent the remaining singles to fill until price moves down to the lowest single print. can this be fixed? That zone is technically still valid. Notice before in the profile prior price moves completely through the zone, and it is cut right there where it clears as it should be. Image link - https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=95505 thats with price split out , below is link with profile normal, you can clearly see the large single zone that still exists, but no zone extending like the rest. https://www.sierrachart.com/image.php?Image=1707440542445.png Date Time Of Last Edit: 2024-02-09 01:03:21
sierra singles .png / V - Attached On 2024-02-09 00:52:39 UTC - Size: 206.84 KB - 206 views |
[2024-02-09 05:35:16] |
Sierra_Chart Engineering - Posts: 14423 |
We are looking this over.
[2024-02-09 09:13:45] |
fried4104 - Posts: 53 |
Looking great! Thanks!!!! As @jmftattoo pointed out, as soon as the price touches a single print area (even for 1 tick), it immediately dissapears entirely. Thanks for looking into it. |
[2024-02-09 16:04:20] |
Thank you. Love the new feature other than that. Thank you all for including it. |
[2024-02-09 17:03:31] |
User302605 - Posts: 23 |
Thank you for this new functionality! It will be so useful. Please consider adding Subgraph capability so that we can select one color to indicate that the single prints were created from the price going up and able to select another color to indicate that the single prints were created when the price was going down. Also, it would be beneficial if we could select whether the future intersection can occur during an Evening session or require the future intersection to only apply during an RTH session. Do you also have plans to apply this same feature to Gaps? Thanks again! A great addition to the TPO study! |
[2024-02-12 17:45:30] |
Any update from dev team on the singles zone's that are not clearing properly? example from todays weekly profile. Clear unfilled single zone up top on period K, that launched, then cleared because price touched it, but did not go all the way through. Then the one below which is still untouched, and working fine. https://www.sierrachart.com/image.php?Image=1707759823416.png |
[2024-02-14 09:46:41] |
Another bug I noticed. Chart is ES. Note yesterday overnight session single print area does not project further than the overnight session (pointed the arrow). That's a singular issue, didn't notice it before. Also is does not get filled when touched (pointed the square area). Sierra 2599 build. Thanks! |
[2024-02-14 11:21:23] |
User688525 - Posts: 195 |
Hello, Can you please direct me to where the "Extend singles as area" setting is? I am on version 2598? Thank you |
[2024-02-14 11:26:54] |
Go to Studies->TPO Profile->Extend Singles as Area
[2024-02-15 00:18:43] |
Hello fried4104, Thank you. Can I ask which version you are using as 2598 (Current Release) doesn't have this option? |
[2024-02-15 07:59:25] |
Ez - Posts: 45 |
I've been testing this in the new release. There are a few issues as jmftattoo mentioned. Also, single prints within the opening range or IB for the current day do not seem to be calculated. Is this by design? Also, how does this handle overnight sessions? does it clear singles or does that depend on whether you have overnight enabled? For example I hide all overnights except the last. Would this follow depending on whether I have have EXT session enabled in tpo? thx. *example of singles during IB https://i.imgur.com/cJoHIu3.png Date Time Of Last Edit: 2024-02-15 08:04:40
Screenshot 2024-02-15 015415.png / V - Attached On 2024-02-15 08:03:31 UTC - Size: 337.17 KB - 73 views Attachment Deleted. |
[2024-02-15 08:36:51] |
@User688525 - im using pre-release versions. (currently on 2602).
[2024-02-15 10:38:19] |
Thank you fried4104.
[2024-02-27 08:19:46] |
ticinotrader - Posts: 378 |
Dear Support, Could you please consider adding the option to highlight the letters of the single print as well? The same functionality already exists for the Midpoint, Open, Subperiod Open/Close, POC, etc. Thank you in advance. |
[2024-04-12 22:11:59] |
User652903 - Posts: 20 |
Another error with singles. See attached. The hot pink shading is the singles area. You can see it's overlapping an area that is not a single print area.
Date Time Of Last Edit: 2024-04-12 22:30:32
Screenshot 2024-04-12 at 6.10.47 PM.png / V - Attached On 2024-04-12 22:11:13 UTC - Size: 102.54 KB - 77 views Screenshot 2024-04-12 at 6.29.56 PM.png / V - Attached On 2024-04-12 22:30:19 UTC - Size: 47.14 KB - 62 views |
[2024-04-16 03:05:55] |
We will check this.
[2024-04-25 22:06:04] |
More problems with singles; see attached. The pink circled single prints area should still be running. The way this should work is that the singles extension box should close down one tick at a time until it is completely filled in. Here it cut off inexplicably, not having been filled in really at all. Would be great to get this working properly. |
Screenshot 2024-04-25 at 6.03.31 PM.png / V - Attached On 2024-04-25 22:05:30 UTC - Size: 664.33 KB - 58 views |
[2024-04-29 22:23:44] |
We are working on this. We did not understand, this is what was required of this type of TPO single highlighting.
[2024-04-29 22:25:43] |
Understood, thanks for addressing
