Date/Time: Sun, 19 May 2024 07:44:19 +0000
TPO Single Prints
View Count: 6357
[2024-01-04 17:15:46] |
@TRADE_YOUR_PLAN - Posts: 126 |
+1
[2024-01-04 17:15:50] |
Technical - Posts: 148 |
+1
[2024-01-04 17:16:36] |
User340846 - Posts: 1 |
+1
[2024-01-04 17:16:45] |
JDN2K - Posts: 2 |
+1
[2024-01-04 17:23:53] |
Optionyout - Posts: 7 |
+1
[2024-01-04 17:25:43] |
bhavs101 - Posts: 1 |
+1
[2024-01-04 17:45:17] |
GARYtheG - Posts: 2 |
+10
[2024-01-04 22:40:58] |
barucho - Posts: 3 |
+1
[2024-01-04 23:36:30] |
User719512 - Posts: 228 |
This exists in the OrderFlow Labs (OFL) AutoPlot tools, among other things. https://twitter.com/orderflowlabs/status/1645809379944566787 AutoPlot is scheduled for release as an independent toolset soon. |
Single Prints.png / V - Attached On 2024-01-04 23:35:30 UTC - Size: 536.95 KB - 103 views |
[2024-01-05 11:16:42] |
User45989 - Posts: 54 |
this is simple enough that it should be included in Sierra natively - no one should have to buy a third party add on to make this work
[2024-01-05 16:00:52] |
It would seem an SG for SP-low and SP-high on the TPO chart would be pretty easy for Sierra to add in a non-breaking manner. If there were 2 SGs for the nearest single print, then you could use Fill Top/Bottom draw styles to visualize the range. It's interesting that you cannot reference the SP subgraph (#31) with study/price overlay and can't put the SPs on another chart either because depending on how the TPO is displayed, expanded/own column or not, the times do not line up. Guess that's the nice thing with ASCIL is that you can detect these with code and 30-minute bars. |
[2024-01-10 14:58:34] |
Userdzungdo - Posts: 2 |
+1
[2024-01-10 15:00:19] |
MrTienDatVn - Posts: 13 |
+1
[2024-01-10 15:01:49] |
OTLSignals - Posts: 4 |
+1
[2024-01-10 16:21:53] |
jmftattoo - Posts: 76 |
+1+1+1+1+1+1+1 This is a must, silly that sierra hasnt included yet. |
[2024-01-21 18:42:57] |
User440951 - Posts: 40 |
+1 I would also like this feature.
[2024-01-30 01:48:40] |
Sierra_Chart Engineering - Posts: 14423 |
This will be out in the next release.
[2024-01-30 03:41:13] |
Mohammad Yousuf - Posts: 2 |
I am very interested this Single print feature.
[2024-02-01 18:36:31] |
ticinotrader - Posts: 378 |
Dear support, I've checked this in the new 2591 but have not found the relevant new options. Am I missing something or it will come later? Thanks in advance! |
[2024-02-01 22:38:21] |
Dear support,
I've checked this in the new 2591 but have not found the relevant new options. Am I missing something or it will come later? Thanks in advance! Same here, have updated to prerelease each day to make sure I didnt miss anything. lol. Not seeing any functionality for this in TPO yet either. When should we expect it? |
[2024-02-02 04:59:14] |
Kelamik - Posts: 11 |
Highly anticipating the Single Print zones, and what I thought was also similar fix for Gap zones. I hope both of these enhancements are coming soon.
[2024-02-05 06:39:52] |
Bumping this for an update from mods? This will be out in the next release.
above posted 01/30, but I still don't see any updates on the prerelease updates that have been pushed in versions 91-95. Are there updates from the dev's? or a actual timeline we can expect this feature to be enabled? |
[2024-02-07 06:14:55] |
turlur - Posts: 3 |
+1
[2024-02-07 06:51:37] |
fried4104 - Posts: 53 |
+1
[2024-02-09 00:37:01] |
This is implemented for anyone that has wondered, I just updated and see it as "Extend singles as area". thank you to sierra for doing this.
Date Time Of Last Edit: 2024-02-09 00:42:06
[2024-02-09 00:59:07] |
@ sierra dev team, the singles should not be deleted fully until the entire zone is back filled with new letters. See example, there is a single zone that was launched, and price started to move back down into it, but fell short of completely moving through the single zone. the high of the singles zone should move down to represent the remaining singles to fill until price moves down to the lowest single print. can this be fixed? That zone is technically still valid. Notice before in the profile prior price moves completely through the zone, and it is cut right there where it clears as it should be. Image link - https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=95505 thats with price split out , below is link with profile normal, you can clearly see the large single zone that still exists, but no zone extending like the rest. https://www.sierrachart.com/image.php?Image=1707440542445.png Date Time Of Last Edit: 2024-02-09 01:03:21
sierra singles .png / V - Attached On 2024-02-09 00:52:39 UTC - Size: 206.84 KB - 206 views |
