Date/Time: Mon, 13 Jan 2025 14:32:21 +0000
local timestamp setting
View Count: 786
[2017-05-01 02:21:47] |
User710890 - Posts: 23 |
Hello and sorry for the trivial question, but you state on this page: http://www.sierrachart.com/index.php?page=doc/helpdetails38.html If Timestamp Using Local Computer Clock is set to Yes/True, then your computer's clock will be used for real-time received data. One is not necessarily better than the other. If you maintain a very accurate computer clock, then typically it is better to use your local computer clock.
I've looked thoroughly and have been unable to find an answer as to why exactly it is 'typically better' to use the local computer clock. Mine is extremely accurate btw, using meinberg ntp. Thank you in advance. |
[2017-05-01 05:35:55] |
We see you are using CQG. Probably would be best to use the CQG provided timestamp and not the local computer clock. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
