Date/Time: Mon, 13 Jan 2025 14:32:59 +0000
Spreadsheet with multiple studies
View Count: 610
[2017-05-01 00:42:41] |
User534090 - Posts: 5 |
When using a spreadsheet system with multiple studies, I'm having a tough time correctly referencing the last bar from studies with different time frames. For example, a 20 min chart would calls a 60 min study as an overlay. On the spreadsheet, the subgraphs show a value, then 0 , 0 then the next value. would using ID2.SG1@3 reference the most recent bar or the most recent value (as ID2.SG1@ cell 3 would be 0 for 2 "ticks" of the 20 min chat)? I'm currently at work and unable to post a screen shot, but I believe the question is straight forward. |
[2017-05-01 05:34:07] |
The best you can do is set this Input to Yes with the Study/Price Overlay study: Study/Price Overlay Study: Fill Blanks with Last Value You should also read the other documentation on that page to have a full comprehension of how that study works. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
