Date/Time: Mon, 13 Jan 2025 17:00:33 +0000
1550 depth issue
View Count: 1219
[2017-05-01 00:00:56] |
User20450 - Posts: 330 |
just updated to 50 and noticed all of the depth is same size on the bars , not the numbers , please advise thanks
Private File |
[2017-05-01 05:30:55] |
We will look into this.
[2017-05-03 12:28:13] |
any word on this ?
