Date/Time: Mon, 13 Jan 2025 09:40:26 +0000
Intra Day volume not matching Daily Volume
View Count: 798
[2017-04-29 22:38:35]
toptrader8 - Posts: 5
Hi I am using Numbers Bars with VOLUME as one of the Calculated Values.
I have checked across several currency futures contracts and the Intra day volume does not add
up to the daily volume. For instance taking Australian Dollar June 17 CME as an example
Intraday hourly volume for 04/28 - 67,422
Daily Volume for 04/28 - 78,817
The daily volume is the correct figure as it matches the volume shown in the CME Stats website.
I am using the delayed data service that comes with service package 5, Updated as of 6.41pm 04/29
Attaching screen shots showing the volume differences
What is going on here??
Date Time Of Last Edit: 2017-04-30 03:01:38
imageA6M17 240 Min #1 2017-04-29 20_00_55.895.png / V - Attached On 2017-04-30 03:00:51 UTC - Size: 55.17 KB - 209 views
imageA6M17 Daily #1 2017-04-29 20_01_22.818.png / V - Attached On 2017-04-30 03:01:01 UTC - Size: 42.68 KB - 217 views
[2017-04-30 16:09:13]
Refer to help topic 43.7:
https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7
