Date/Time: Fri, 11 Sep 2026 04:20:24 +0000
Intelligent stop management possible?
View Count: 916
[2017-04-29 04:58:48]
tobi - Posts: 351
Is it possible to achive the following within the DOM / target and stop management?
Attached orders (10 points stop and 10 points target) checked
Long entries (e.g):
1st position entry at 10.050 (=> stop at 10.040, target at 10.060)
2nd position entry at 10.048 (=> stop at 10.038, target at 10.058) -> I manually change the target to 10.056; stop stays at 10.038
3rd position entry at 10.053 (=> stop at 10.043, target at 10.063) -> I manually change the target to 10.054; stop stays at 10.043
Target of the 3rd position (10.054) gets hit => Not the stop of this position (10.043) should be deleted but the stop furthest away (10.038)
... and so on
In other words, is it possible that when working with several individual entries (with attached orders) and the position is being reduced (target/limit reached or manually reduced by market order), that the stop furthest away will be delete and not the stop related to the attached order that is just being closed? Is there any way to achive this?
Date Time Of Last Edit: 2017-04-29 11:26:42
[2017-04-30 18:12:33]
No, this would take custom programming using ACSIL to accomplish this.
Yes this can be done. Refer to:
Attached Orders: Scaling Out
