Date/Time: Mon, 13 Jan 2025 09:30:50 +0000
AMP got hacked - is my sierra chart user data safe?
View Count: 1750
[2017-04-28 21:30:41] |
User554317 - Posts: 59 |
I'm sure most have heard of this by now. https://futures.io/brokers-data-feeds/42120-amp-trading-data-breach-70-gigs-100k-files-customer-data.html My question is, should I change my sierra chart password just to be safe? And if so, how do I do that? Thank you! |
[2017-04-28 21:51:48] |
Yes you can change your Sierra Chart password here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Also for the record Sierra Chart does not store any sensitive information other than users who are using the CTS order routing connection and that information is encrypted with multiple layers. And not accessible by anyone even including us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-28 21:52:54
