Date/Time: Mon, 13 Jan 2025 09:42:11 +0000
Rithmic feed into Sierra
View Count: 692
[2017-04-28 18:57:19] |
User35326 - Posts: 57 |
SC: Is it okay with Sierra, if I have one instance of Sierra on one computer and another instance of Sierra on a second computer and both of them are using the same login to Sierra. I think it is ok since it is done with a Transact feed. I will be feeding Sierra using Rithmic. Thanks in advance. |
[2017-04-28 19:12:06] |
Yes this is fully supported.
