Date/Time: Mon, 13 Jan 2025 14:36:36 +0000
Moving Data folder
View Count: 1679
[2017-04-28 14:26:45] |
BenjaminR - Posts: 170 |
Can I move the Data folder from (C:)>Sierra Chart>Data to another drive, and redirect the software to find it there for normal operations? If so, quick how to? (I know how to move it of course, but the redirecting part - I don't want to experiment with this at this time). Thank you ~ Ben |
[2017-04-28 17:27:56] |
Yes. Refer to: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#DataFilesFolder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-01 01:23:46] |
Okay worked that out just fine; however, can't seem to do the same for the data files of Sub-Instances. I was also sure to uncheck the "Always use data folder within main folder" tick box in General Settings on each sub-instance. Please advise. Thanks, Ben Date Time Of Last Edit: 2017-05-01 01:24:43
[2017-05-01 05:35:09] |
We would have to check but you probably cannot use a nonstandard Data folder for a sub instance. It would always revert to the standard folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-05-01 12:13:12] |
Okay thanks, please let me know. My primary data folder had reached 19 GB in size, and 1 of the Sub-instances is about 6 GB. If there's tips and tricks to reducing the size of an overgrown data folder, please advise. I do use monthly charts for a couple instruments, but I wouldn't think OHLC data is very big. |
[2017-05-01 16:09:34] |
We have verified this is not supported for sub instances. We do not want to make any changes with this to avoid unexpected complications. Refer to: http://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#DataFileManagement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
