Date/Time: Sun, 21 Jun 2026 12:30:49 +0000
s_SCPositionData members - LastEntryDateTime & LastExitDateTime
View Count: 858
[2017-04-28 02:04:42]
User553714 - Posts: 184
Hi, I am using the following method to retrieve the bar Index of the LastEntryDateTime & LastExitDateTime of the last position;
  SCDateTime LastEntryDateTime = PositionData.LastEntryDateTime;
  PositionEntryIndex = sc.GetContainingIndexForSCDateTime(sc.ChartNumber, LastEntryDateTime);
  SCDateTime LastExitDateTime = PositionData.LastExitDateTime;
  PositionExitIndex = sc.GetContainingIndexForSCDateTime(sc.ChartNumber, LastExitDateTime);
Would this be the most reliable way of retrieving the Index of the last position (Entry & Exit) or can you suggest a better method? I am asking since at times the method works perfectly at other times it seems to become unreliable.
I think it may be related to when I am cancelling orders that haven't filled; are orders that haven't filled and which are cancelled considered "Positions?" In such a circumstance using the above method for retrieving the "LastExitDateTime" BarIndex recursively returns the Current sc.Index which seems like odd behaviour as I am using "PositionData.LastExitDateTime"? Any suggestions will be appreciated. Thanks
[2017-04-28 05:07:26]
That is the right method. However, you might want to use the functions to get a nearest match instead of a containing match.
No.
