Date/Time: Mon, 13 Jan 2025 14:41:52 +0000
SC Newbie questions
View Count: 722
[2017-04-27 22:15:14]
User137998 - Posts: 13
New to SC, couple questions. Would be using SS for Trading.
Is it possible to limit the number of trades per symbol?
Thx Steve
Date Time Of Last Edit: 2017-04-27 23:43:38
[2017-04-28 00:59:19]
I see that you can limit by time range. Spreadsheet Systems, Alerts and Automated Trading: Limiting Trading to Certain Time Ranges
Can I create a formula to say limit a symbol to 1 trade per day?
[2017-04-28 05:05:56]
The quantity is set through this Sheet Cell:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#CellJ26
Also is it possible to set the time I want to start trading without using "trading locked" method?
Refer to:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#AllowTradingOnlyDuringTimeRange
[2017-04-28 13:17:08]
Thx. Can I limit the amount of trades I want to take per symbol. Say I want to only take 1 trade on AAPL not dependent on time-frame.
Date Time Of Last Edit: 2017-04-28 13:59:55
[2017-04-28 17:48:28]
Yes you can use this Sheet cell in your formulas:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#CellJ52
[2017-05-01 16:00:18]
Can order quantity (J26) be also used to trade using a fixed dollar amount. Say I want to only trade using $1000.00 allotments?
[2017-05-01 16:20:14]
You would have to therefore calculate with a formula the order quantity according to your needs.
