Date/Time: Mon, 13 Jan 2025 16:45:22 +0000
Number Bar Study - Text Coloring Methods
View Count: 843
[2017-04-27 21:30:37] |
Tojo - Posts: 4 |
When using the number bar study, I prefer to display text with the "ask bid vol difference diagonal". This text type option yields numbers that are either positive or negative. I can not find a method to color the text when using the "ask bid vol difference diagonal" text type option. Visually, it would be nice to quickly distinguish between the positive and negative numbers by different colors. |
[2017-04-28 16:55:12] |
This does not currently exist: Visually, it would be nice to quickly distinguish between the positive and negative numbers by different colors. The current text coloring methods are documented here: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextColoringMethods Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-28 18:29:59] |
Tojo - Posts: 4 |
Are there any plans to add this coloring method? Since numbers can be displayed with "ask bid vol difference diagonal" it is logical that a coloring method would also be available to be used with the text method. Hence the inquiry as to whether there are plans to make this available sometime in the future. |
[2017-04-29 00:53:09] |
Yes, we are going to do some work on the Numbers Bars study and we will see about this.
[2017-05-03 04:42:43] |
The new coloring method will be out in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-05-03 04:42:55
