Date/Time: Mon, 13 Jan 2025 09:32:31 +0000
referencing studies within the same chartbook
View Count: 894
[2017-04-27 16:10:45] |
fatdogtrades - Posts: 2 |
Support --I use the Initial Balance study on a 15 minute based chart in my chartbook. (this works fine) I also have an other chart in the same chartbook using Flex-Renko bars (12-10-0). The Initial Balance study on the Flex Renko chart does not display the accurate prices for the Initial period. I'd like to reference the Minute based chart for the IB study in the Flex Renko chart for true accurate prices at specific times. How can I do that? Thanks, Bob |
[2017-04-27 17:50:55] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
