Date/Time: Mon, 13 Jan 2025 09:46:55 +0000
My Bund footprint/Number bar char is very wrong
View Count: 847
[2017-04-27 13:30:40] |
User376900 - Posts: 1 |
Has anyone any idea why my footprint doesnt work properly? Images titled right is correct, image titles wrong is incorrect. Any help much appreciated. Date Time Of Last Edit: 2017-04-27 13:31:38
[2017-04-27 17:24:00] |
Make sure Sierra Chart is set to a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php And disable the Volume Filtering: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#VolumeFiltering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
