Date/Time: Mon, 13 Jan 2025 09:38:17 +0000
Closing Sierra Chart - open orders getting canceled?
View Count: 1148
[2017-04-27 07:57:36] |
User514837 - Posts: 47 |
If I am in a position with 2 orders (one stop order for stop loss and one limit order for take profit), and try to close Sierra chart, I get a message saying that I have open orders, and if they include client side managed attached orders or trailing stop orders they will no longer be managed. What does that mean? Will they not work if I exit Sierra chart? And how can I make it possible for orders to work even if I close?
[2017-04-27 17:45:06] |
Will they not work if I exit Sierra chart? If they are client-side managed, then no. And trailing stop orders will not be managed in any case.And how can I make it possible for orders to work even if I close?
You need to enable this option to solve this: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideBracketOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-27 17:46:13
