Date/Time: Mon, 13 Jan 2025 11:40:58 +0000
Data Feeds
View Count: 745
[2017-04-26 22:05:41] |
dennismed - Posts: 62 |
Which data feeds do I need to subscribe to for $IXM, $SPX, $BANK I want to ensure I am subscribing to the correct services. Thank You
[2017-04-27 04:12:33] |
You can see the exchange at the end of these descriptions: $IXM: S&P Financial Select - S&P Indices $SPX: S&P 500 Index - CBOE Indices $BANK: Nasdaq Bank Index - NASDAQ Indices So you just need to add CBOE Indices here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-04-27 04:12:53
