Date/Time: Mon, 13 Jan 2025 11:56:44 +0000
EMA values over CCI
View Count: 650
[2017-04-26 20:12:31] |
markuz - Posts: 90 |
Hello, I added a EMA on top of my CCI. It defaulted the values of the EMA, how do I change them back to the CCI (picture attached)
Attachment Deleted. MA_values_over_CCI.png / V - Attached On 2017-04-26 20:12:09 UTC - Size: 78.71 KB - 260 views |
[2017-04-27 04:33:17] |
You will need to make sure that the Commodity Channel Index is listed before the Exponential Moving Average. Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
